Oil lamp and ticking at 170k: Suggestions on where to start
Old Jan 6, 2018 | 05:46 PM
  #171
The Deputy's Avatar
Originally Posted by CaptainAaron
While I can't speak for the other forums, from what I've seen on here, yes, I agree Julian has badmouthed some suppliers. I believe that most people know that some of those accusations were unfounded, especially because of the unwavering support for most suppliers by the members on this forum and others. All I'm saying is at this point, reprimanding him is just beating a dead dog. In my mind, these forums are about helping others with a common passion. I'd give the man a hand up in time of need, even if it is self-inflicted.
Just my 2 cents, please carry on. I hope Julian can get this resolved, in whatever way possible.
Agreed. Keep the drama and dead horse beating for someone that cares. We just want to discuss the rover issues at hand.
Old Jan 6, 2018 | 06:01 PM
  #172
number9's Avatar
Thanks.
  #173
Lisa Bunch's Avatar
Ok, I looked at my service manual, correct me if I'm wrong, I really want to know the cause of this failure...
The oil pump picks up oil from the sump (suction).
It then goes to the oil cooler if equipped. (pressure)
Then to the oil filter. (pressure)
Then to passages in the engine. (pressure) Drops back into oil pan, cycle starts over.
15w-40 Rotella T. In NH in winter.
Was oil too thick to circulate through filter and system?
OverRover was onto something with warm engine/cold filter test.
Old Jan 6, 2018 | 06:19 PM
  #174
TRIARII's Avatar
My cousin was thinking the same thing. However the mechanic said that once the truck warmed up during idle that the internal heat should have been hot enough to warm up the oil thus allowing circulation throughout the engine. Also I dont believe my truck has an oil cooler. I think those were fitted to older D2's.
Old Jan 6, 2018 | 06:32 PM
  #175
Robert Booth's Avatar
I might have missed it but have you removed and checked the oil filter?
back in the day (1980’s) I had the oil filter fail on a mini 850 in cold weather. It resulted in oil starvation and a lunched engine.
Old Jan 6, 2018 | 06:36 PM
  #176
OverRover's Avatar
You have the flow right, + or - the oil cooler.
Old Jan 6, 2018 | 07:01 PM
  #177
TRIARII's Avatar
oil filter was removed but the mechanic made no mention about anything with the oil filter.
Old Jan 6, 2018 | 07:13 PM
  #178
Lisa Bunch's Avatar
What if the oil filter was blocked with cold oil, and the bypass too? And the pickup screen/tube?
Leave a jug of rotella t outside overnight, and try to pour it in the morning. That will give you some idea what your engine has to overcome.
Old Jan 6, 2018 | 07:20 PM
  #179
TRIARII's Avatar
I did clean the pickup tube and ran running water threw it, poured out the other side no problem. So it does not appear to be clogged. Nothing dark or otherwise nasty came out.
Old Jan 6, 2018 | 07:41 PM
  #180
shanechevelle's Avatar
Is there an O ring on the tube?
Did you cut open the filter? Go get your filter and cut it open. Look for metal.
I don't think I would worry about the flow through the filter, I've seen the oring blow out when the path is restricted.
