Oil Leak Guide
Old Aug 4, 2008 | 01:11 PM
Dino76's Avatar
Default Oil Leak Guide
Ok I know the all rovers will all leak at some time and that the only way for me to find the source is to take a look after a good cleaning. I have found in my research that the Heads, valve covers, and exhaust gaskets are the more common sources of the leakage. Are there any other areas that I should be looking at first? I recently did the plugs and wires and didn't notice any oil under the intake. Last time I was under the truck I noticed the oil was coming down the back of the motor and falling on the cross member. Any suggestions or recommendations before I get started would be great.
Old Aug 4, 2008 | 03:59 PM
Default RE: Oil Leak Guide
Front crank seal, rear crank seal, oil sending unit, valve covers, power steering lines, trans cooler lines, oil cooler lines, front diff seal, rear diff seal, t-case seals, trans seals, see, thats why we need to club seals. So they dont leak on our garage floor.
Old Aug 4, 2008 | 04:18 PM
Switzer's Avatar
Leaks from valve cover (especially passenger side) are usually caused by a clogged PCV valve. Once I replaced mine the oil leak went away.
Cheers,
Pete
Old Aug 4, 2008 | 06:15 PM
ORIGINAL: Switzer
Cheers,
Pete
V/C gaskets leak because the bolt loosen up, so retighten them and most of the oil will stop flowing.
Old Aug 4, 2008 | 09:35 PM
roverguy7's Avatar
spike, you left off front cover, oil pan and the infamous crusifix seals
bmwkiller
Mar 6, 2008 11:03 AM
BYURover
Jul 25, 2007 12:59 PM
JimMayor007
Tires
Jun 24, 2007 06:34 PM
EVN137
Jun 15, 2007 06:54 PM
Spyderman
Tires
Nov 28, 2006 05:51 AM
