Oil leak in my 04
Old Feb 10, 2019 | 05:18 PM
Daytoman's Avatar
Default Oil leak in my 04
When I was under the 04 yesterday I wiped down just about everything underneath so I could get back under it and see if I could tell where the big leaks are coming from. So I crawled under today after a roughly 10 mile drive.
Its got a lot of oil dripping down the oil filter. It is on tight. That was completely clean this morning. Anyone have any ideas on this?
Old Feb 10, 2019 | 05:21 PM
redwhitekat's Avatar
Maybe the o ring seal failed on the oil filter
Old Feb 10, 2019 | 08:20 PM
Daytoman's Avatar
Sure looks like it! It’s blowing oil around quite a bit. It’s on the steering damper, sway bar and front axle. It’s about due an oil change so I guess Ill find out.
Best4x4's Avatar
Check the large 7/8 plugs for the 99-02 oil cooler line ports. You have an 04 so instead you have large plugs vs lines. They can seep/leak, and if the leak is above that it’s either the oil pan gasket or front timing cover.
Old Feb 10, 2019 | 08:21 PM
Daytoman's Avatar
Will do!
Old Feb 10, 2019 | 08:53 PM
OverRover's Avatar
Definitely have a look around the Oil Filter Adapter (#7 in pic).
If that's the source of the leak then the O ring is toast.
First check if the 4 bolts that hold the adapter on are tight, but it's still good practice to replace the o ring.
Old Feb 10, 2019 | 09:03 PM
Daytoman's Avatar
Thanks!! I got an oil change coming so its something I’ll check.
Old Feb 11, 2019 | 02:55 PM
NVDiscovery's Avatar
my 04 does the same thing using M1 oil filters. I may change to K&N next time to see if the drip stops.
Old Feb 11, 2019 | 05:43 PM
Extinct's Avatar
If you have not done the PCV mod it may be leaking at the cam sensor, if you do the PCV mod all your top end leaks will go away.
Old Feb 11, 2019 | 07:25 PM
Daytoman's Avatar
Yes sir I did that and it made a difference.
John Kim
Jan 23, 2025 08:07 AM
ljdiscovery
Jan 17, 2019 12:23 AM
BowRat
May 18, 2018 05:25 PM
redwhitekat
Apr 20, 2018 10:36 PM
bentonrover
Freelander
Jan 3, 2010 02:52 PM
