Oil Light
Old Jan 8, 2008 | 03:39 PM
PCZ's Avatar
PCZ
6th Gear
Default Oil Light
My oil light came on after washing the engine. seems to run fine & does eventually go out. Any Ideas?... oil sending unit?
Old Jan 8, 2008 | 04:10 PM
Default RE: Oil Light
If it doesn't go out over the next day, I would suggest you track down the sensor and dry out the connection.
Old Jan 8, 2008 | 04:17 PM
PCZ's Avatar
PCZ
6th Gear
thanks mike... have read many of your posts and very informative... I don't have my manual with me so where do I need to look?
Old Jan 8, 2008 | 04:42 PM
As long as you are not getting any noise it is probably safe to say it is the switch and not an oil pressure issue.
Old Jan 8, 2008 | 04:50 PM
PCZ's Avatar
PCZ
6th Gear
That was my thinking... a little to coincidental... I am in the military and work out of town durring the week so I won't have access to my workshop manual until this weekend. Will put it in the vehicle then!!!... Can you clue me in to where the sending unit is on the block and the route of the wiring harness?
Also want to thank the other folks for their knowledge and input in the forum. Great reading!
Old Jan 8, 2008 | 05:02 PM
okdiscoguy's Avatar
Look around where the oil cooler lines attach, right by the filter. Should be right above that. You can get a replacement at Autozone...
(This is for a D1, but a D2 should be close...)
Old Jan 8, 2008 | 05:10 PM
PCZ's Avatar
PCZ
6th Gear
Thanks... luv learning about my disco. Changed front drive shaft about a month ago. Gave me plenty of warning...paying attention was the key.
devildollnyc
Dec 25, 2018 05:12 PM
mikec205
Nov 18, 2014 07:37 AM
drewski
May 31, 2013 10:50 AM
tacker
Jul 10, 2010 09:36 PM
shagybruce
Feb 8, 2007 02:52 PM
