Oil light at idle
Old Oct 26, 2007 | 08:45 PM
  #21
Default RE: Oil light at idle
ORIGINAL: foscaldo
I put a gauge on it and it shows a hair over 6 psi when idling and when you accelerate it goes up. Any thoughts?
Rover lost alot of 03 engines due to bad oil pumps. At the pressure you are talking about, I wouldn't drive the truck till; you verify the pressure both at an idle and 2000 RPM's when cold and at operating temp.
If still low do an oil pump replacement before it is drive much more or you'll be looking for an engine.
Old Oct 26, 2007 | 09:01 PM
  #22
foscaldo's Avatar
4wd High
I forgot to mention he did also replace the sender unit which seemed not to do anything. Any clue on how much I should be paying to have the oil pump replaced? It would be helpful to have a ball park so I am not taken to the cleaners.
Old Oct 26, 2007 | 09:17 PM
  #23
Mid 20 pound range at idle going up to mid 40's at 2000 RPM's.
Old Oct 26, 2007 | 09:37 PM
  #24
Fonzie's Avatar
I had this exact same experience with my 2000 Grand Cherokee: Ran the pressure tests, replaced the sender unit, replaced the oil pump and ended up having to replace the engine...all told: $5,000.
The oil pump was indeed the problem, but by the time it was replaced the damage was already done...crank bearings had worn to the point that even a new oil pump couldn't maintain the required pressure at idle, so the oil light would come on. I had unwittingly inherited this problem from the previous privateowner just one week after I bought it.
Moral of the story is: If the oil light is coming on at idle, don't wait to replace your oil pump. Stop driving it, get it towed and replace the pump.
Since I also have an '03 I'm considering changing my oil pump for the new improved design even though I don't have the oil light at idle...yet!
Discover2
Jan 15, 2014 09:03 AM
javoli002
Oct 30, 2009 10:51 PM
javoli002
Defender
Aug 25, 2009 10:20 PM
DanR
Jun 13, 2009 08:32 AM
westernsun
May 27, 2006 04:24 PM
