oil light on at idle only
Old Jul 12, 2019 | 09:59 AM
jastutte's Avatar
Default oil light on at idle only
like the thread title says, the oil pressure light only comes on at idle. i have read that this is caused by the bearings. is this the case? or are there other possible causes?
i would assume if the oil pump was bad then pressure would be low at all times?
Thanks,
Old Jul 12, 2019 | 10:01 AM
CollieRover's Avatar
Dumb question, but have you checked your oil level?
Old Jul 12, 2019 | 10:20 AM
jastutte's Avatar
double checked the oil level and it's good.
using 5W40 full synthetic. i have use this in all my rovers.
Old Jul 12, 2019 | 10:28 AM
Richard Gallant's Avatar
Could be the oil pump it is a gear driven unit, very old school, it will turn slower at low RPM. They have been known to crack which will reduce overall pressure.
Check this old thread out https://landroverforums.com/forum/di...il-pump-45583/
Old Jul 12, 2019 | 10:31 AM
Luc1f3r's Avatar
Oil pump could be on its way out. Could also be excessive bearing clearance.
I had a supercharged LS motor that had that issue on 5w30 switched to 10w40. This was at 70k miles. I sold the car at 130k miles and motor was still fine.
Old Jul 12, 2019 | 11:25 AM
Dave03S's Avatar
Put some 15w40 in it and see if it still happens.
Old Jul 12, 2019 | 12:34 PM
Best4x4's Avatar
Oil Sensor wiring ok? If it goes to ground = light.
Old Jul 12, 2019 | 02:40 PM
Externet's Avatar
Even with the oil pump in good condition, pressure can drop if its pressure regulator (picture) is stuck open because of crude build-up, broken spring, worn parts, or lazy electrical sensor...
Edited : Look at the drawings ----> https://landroverforums.com/forum/di...ng-part-95586/
Old Jul 12, 2019 | 07:56 PM
Extinct's Avatar
Could also be caused by a walked cam bearing. We need to see the oil pressure hot and cold, also at idle and 2000 rpm. How long have you had it, how long has oil light been on? You can check bearings and by dropping the pan, takes about a half an hour to get it off. If it is not the bearings, you can then think about pulling the front cover oil pump - figure 2 more hours for that.
Old Jul 14, 2019 | 10:30 PM
00&04 Disco's Avatar
I agree with a walked cam bearing. I have seen some worn cam, crank and rod bearing and no oil light. If it is on only during idle or low RPM it points to cam bearing. This was the case in my 04 when I pulled it apart. Oil pump good, crank and rod bearings showing a little wear and one walked cam bearing. If you don't want to pull the pan it is also easy to diagnose by pulling off the intake, injectors and valley pan, it opens up the top of the motor and you can easily see all of the cam, cam bearings/races. Best of luck!
zer0Point
Feb 16, 2020 05:38 PM
lrjon
Apr 12, 2015 02:37 PM
rewi9d
Apr 12, 2012 06:12 PM
felipenaves
Jun 6, 2010 04:57 PM
DanR
Jun 13, 2009 08:32 AM
