Oil light on, not low on oil
Old Nov 17, 2014 | 11:46 AM
sdhow's Avatar
Default Noise
Originally Posted by mikec205
Mystery solved....oil pump came apart and took out a big chuck of the timing chain cover. No large debris in the oil when I pulled the pan. However after I drained the oil out of the pan you could see very tiny sparkles of gold ie: brass or copper.
Did the engine make a "tick-tick-tick" at low idle?
Old Nov 17, 2014 | 12:33 PM
Yoops Racing's Avatar
A new oil pump gears and cover at the least.....same happened to me at 83k miles. After HG job and this..I had no hope of ever having any confidence in the stock motor, I ended up tossing the motor for a rebuilt Tophat lined Cannibal V8...good luck
Old Nov 18, 2014 | 07:37 AM
drowssap's Avatar
new oil pump, used cover, put it together and hope for the best. if there was enough metal to get into your rods and mains, there was enough to get to every other part and oil port in the engine also. Pump, cover flush and hope. if need be turner is blowing out top hatted 4.0 for less than $4k.
srockrae
Sep 3, 2012 06:08 PM
Cessna310Guy
Dec 7, 2008 02:38 PM
dinandan
Apr 23, 2008 09:17 AM
Classic89
Aug 10, 2007 08:58 PM
houstonhelix
Apr 26, 2007 10:52 AM
