Oil Pan Gasket?
Old Sep 28, 2009 | 10:11 PM
bikingteacher's Avatar
Default Oil Pan Gasket?
Looking ahead for my next project I ordered a new oil pan gasket. I have been losing some oil and after having the heads done I want to try and keep the fluids in the truck. (I know, a novel thought for a Rover). Looking at the Rave manual--I will need to remove the frame cross-member to drop the pan.
After I drop the frame piece it says to, "Disconnect and release gearbox oil cooler pipe and discard 'O' ring."
Do I need to buy an O ring for this project too? I would like to do this in one weekend and not be waiting for some little O ring before I can drive again.
My list should include,
Gasket, Mineral spirits and scotch brite pad, scraper, oil, oil filter.
Anything else? (Besides beer?)
Re-use the O ring or what?
Old Sep 28, 2009 | 10:13 PM
Well, I think I should have just ordered it from AB, here is the O ring
http://www.roverparts.com/Parts/ESR1594L.cfm
Old Sep 28, 2009 | 11:04 PM
grussell's Avatar
Tough, when you have the only answer for you question. If you are going to change the pan gasket to stop leaks, then replace the oring too.
mike111
Jun 2, 2014 08:58 AM
jpmiller
Sep 26, 2012 06:32 AM
afphinfan
Jan 5, 2008 11:04 AM
91rover
Jun 13, 2007 03:15 PM
modelwerks
Oct 13, 2005 05:39 AM
