Sponsored by: CARiD
oil pan removal
Old Jul 19, 2007 | 12:35 AM
91rover's Avatar
6th Gear
Default oil pan removal
how would i remove the oil pan on a 91 RR?
thanks in advance
Old Jul 20, 2007 | 02:59 PM
91rover's Avatar
6th Gear
Default RE: oil pan removal
Anyone have any suggestions on how to remove the pan?
Old Jul 20, 2007 | 03:38 PM
I can't remember, is there a cross member or something in the way, is that what your quest is for, other wise just pull all the securing bolts and your in.
Why are you wanting to remove the pan?
Mike
Old Jul 20, 2007 | 05:59 PM
91rover's Avatar
6th Gear
i need to replace the gasket, it spring a leak.
when i got a galnce under there is a cross member there. i dont think i need to lift the engine to get the pan do i?
Old Jul 27, 2007 | 05:04 AM
Pierre's Avatar
Drain the engine oil, move the tranny cooler lines aside. Remove the sump bolts and drop the pan. Is there a sway bar you need to shift? You may need to detach the diff end of the steering damper as well.
HTH
mike111
Jun 2, 2014 08:58 AM
Dan7
Feb 26, 2014 09:06 PM
MrFlea1
Dec 22, 2011 04:31 PM
Bryan H
Oct 8, 2010 12:06 AM
lipadj46
Nov 17, 2009 11:13 AM
