Oil pan won't drop
def check the Rave. I did mine a couple of weeks ago- printed out the two pages and just kept looking for nuts and bolts to remove. as previous poster said- it may take a little "persuasion" from a rubber mallet if sealant was used. IIRC there are 4 bolts on the rear part- 2 forward facing, 2 rear facing, plus the deep-set 2 you said you found. those were the ones I missed first time around.
