Oil pan won't drop
Old Mar 9, 2015 | 08:55 AM
SailorTom's Avatar
8th Gear
will do thanks
Old Mar 9, 2015 | 11:18 AM
jamestfl's Avatar
def check the Rave. I did mine a couple of weeks ago- printed out the two pages and just kept looking for nuts and bolts to remove. as previous poster said- it may take a little "persuasion" from a rubber mallet if sealant was used. IIRC there are 4 bolts on the rear part- 2 forward facing, 2 rear facing, plus the deep-set 2 you said you found. those were the ones I missed first time around.
Old Mar 9, 2015 | 07:58 PM
SailorTom's Avatar
8th Gear
ok it was the two in the deep holes in the back of the pan. Thanks so much for the help! I'll continue with the project.
cmthompson
Dec 15, 2014 05:11 PM
shonuff93
May 6, 2013 10:47 AM
vandal996
Jan 31, 2011 09:24 PM
rlrigsby
Feb 12, 2010 08:53 AM
freeranger
Mar 29, 2005 06:03 PM
