Oil Pressure
Old Mar 8, 2015 | 01:22 PM
redrover75's Avatar
Default Oil Pressure
Does anyone know where to attach an oil pressure gauge, if I am not using the oil filter attachment?
I am thinking of the Harbor Freight kit, $25, it comes with a number of threaded fittings and looks simple to use. Where would it plug in?
thanks,
Old Mar 8, 2015 | 01:54 PM
ralphobell's Avatar
Do you have an oil cooler on your rig? If not there is a port you can use near the oil filter.
Old Mar 8, 2015 | 03:33 PM
Broken08's Avatar
where does an oil cooler live? and if I don't have one, should I add one?
Old Mar 8, 2015 | 06:08 PM
ralphobell's Avatar
The early D2's came with them. The later models usually didn't. What year model do you have?
Old Mar 8, 2015 | 07:10 PM
Lowest Bidder's Avatar
If you don't have the oil cooler, then I think the easiest way is to do like I did and drill the plug where it would have connected to the oil pump cover, then thread the hole for 1/4" NPT. I had a picture of that somewhere, but I can't find it right now.
Old Mar 9, 2015 | 09:14 AM
dusty1's Avatar
or $20 gets you
Oil Filter Sandwich Adapter 1 8 NPT Pressure Temperature Temp Sender Sensor | eBay
Old Mar 9, 2015 | 11:07 AM
drowssap's Avatar
a sandwich is the quickest and easiest way
Old Mar 9, 2015 | 03:45 PM
coors's Avatar
I'm running the Sandwhich adapter w/ an M1-301 extra large capacity filter without any fitment issues. It's way easier than drilling, taping, etc...
Old Mar 9, 2015 | 07:19 PM
dr. mordo's Avatar
The problem with sandwich adapters is they give you pressure before the filter, which is different from the pressure flowing into the engine.
Still better than nothing, I guess.
Old Mar 10, 2015 | 01:13 PM
DustyLBottoms's Avatar
I used the port above the factory oil pressure switch, and also added the oil cooler & lines from an earlier D2.
https://landroverforums.com/forum/di...e-gauge-70216/
eaglewing
Apr 16, 2011 11:06 AM
Snafu / Disco Fries
Feb 24, 2011 09:10 PM
lipadj46
Oct 17, 2010 06:34 PM
tito5590805
Oct 4, 2010 09:11 AM
DooDer
Jan 12, 2010 10:46 PM
