Oil pressure drop!
Old May 6, 2013 | 08:47 AM
and sure the chamfered edge of the outer gear faces down into the timing cover. While apart may want to look at the relief valve for scoring, etc.
Old May 6, 2013 | 08:51 AM
drowssap's Avatar
the factory gears have a tapper that the aftermarket gears do not, so unless you put in LR oem gears it probably isn't your problem.
Old May 6, 2013 | 10:47 AM
shonuff93's Avatar
I will pull the pan and front cover again and check it out. Thanks guys. I'll get back to you shortly, hopefully with some pics. Is it OK to pull the bearings and reinstall if they check out? Or do I need new bolts.
SailorTom
Mar 9, 2015 07:58 PM
Gaborover
Oct 1, 2013 08:43 PM
vandal996
Jan 31, 2011 09:24 PM
rlrigsby
Feb 12, 2010 08:53 AM
DooDer
Jan 12, 2010 10:46 PM
