oil pressure, knock sensor, oil pump... stuff
Old Jun 17, 2023 | 02:12 PM
cappedup's Avatar
Octane booster made no difference.
But.. the leaf blower and soapy water trick showed big exhaust leak where the header meets the y pipe on the drivers side.
started the car and I can hear a ticking in that area.
not sure whether to pull the joint apart and put it back together better or just drop the $$ on a new Y pipe and cats etc.
Old Jun 18, 2023 | 12:25 AM
V50-M66's Avatar
Try pulling it apart and tightening it up. Mine has a leak in the same spot, and pulling it apart, re-aligning everything, and replacing the gasket solved the leak.
Old Jun 20, 2023 | 02:09 PM
NVDiscovery's Avatar
Originally Posted by Extinct
Do the shop-vac/leaf blower exhaust leak test to rule out that as your noise. You shouldn't have an engine knock with that kind of oil pressure and I can almost guarantee it's not a knock sensor pre ignition issue as discos never really have those even with bad sensors
Would you explain this procedure? I have a similar issue and it may be the passenger side exhaust connections.
Thank you.
Old Jun 20, 2023 | 05:38 PM
greisinb's Avatar
Thank you.
In a spray bottle mix up a solution of soapy water. Next, stick the blower/outlet side of a shop vac into your tailpipe (I used some duct tape to hold it/seal it) and turn it on. Spray the solution at your exhaust system, the pressure from the shop vac will cause bubbles to form at the location of any leaks.
Old Jul 11, 2023 | 07:14 PM
cappedup's Avatar
Anyone that mentioned exhaust gaskets, ding ding ding. Winner.
Leaf blower up the back and soapy water pointed me to the 2x Y pipe gaskets.
Could almost hear the ticking when I was closer to the leaks.
I looked at the bolts and instantly decided to put it in a shop. Not tackling that.
2 weeks later and 2 shops later, I get the car back. Astonishing amount of labor to drill out rusted bolt stubs. One option was to remove manifolds, I opted against that. Had to take it off one shop who’s competence I didnt trust.
Anyway, first drive and my tick/knock/noise has gone.
Of course now that’s gone I can hear something else. Haha.
MaineLR3
May 30, 2025 04:39 PM
Charlie_V
Jan 6, 2016 01:41 PM
velija
Mar 11, 2014 01:59 PM
ArmyKen
Apr 10, 2011 09:16 PM
morzy41
May 11, 2010 11:39 AM
