Oil Pump
Oil Pump
Hi all,
I am getting everything together to do Timming chain and gear replacment as I am long overdue (212,000 miles) plus the cover is leaking oil. My question is while I am there should I order new oil pump gears or leave well enough alone, the old saying if it aint broke dont fix it?
Sorry, I mis-read your thread, yes, do the oil pump and possibly the water pump if it has lots of miles on it, making sure to get rid of the Dexcool and replace the t/stat and coolant pressure cap cause they both disolve over time because of the Dexcool.
Do you have the new style upper radiator hose with the bleed screw located in the tee, if not, order that also before your fails.
