Oil Pump
Old Feb 9, 2012 | 10:55 AM
05gixxer's Avatar
Default Oil Pump
Hi all,
I am getting everything together to do Timming chain and gear replacment as I am long overdue (212,000 miles) plus the cover is leaking oil. My question is while I am there should I order new oil pump gears or leave well enough alone, the old saying if it aint broke dont fix it?
Old Feb 9, 2012 | 11:37 AM
You always replace the gear when replacing the chain due to long term wear that will cause a new chain to wear faster.
Make sure to flush out the old Dexcool if you haven't yet and go green along with a new t/stat.
Old Feb 9, 2012 | 11:42 AM
05gixxer's Avatar
Yes the plans are to do the chain and the two sprockets as a set. but should I also replace the oil pump gears as well while I am there.
Old Feb 9, 2012 | 02:42 PM
94svt50's Avatar
Yes, with that many miles I would replace the pump gears since you already are going to have the cover off.
Old Feb 9, 2012 | 07:37 PM
drowssap's Avatar
200000 miles i think its earned a rest
Old Feb 10, 2012 | 06:30 AM
Sorry, I mis-read your thread, yes, do the oil pump and possibly the water pump if it has lots of miles on it, making sure to get rid of the Dexcool and replace the t/stat and coolant pressure cap cause they both disolve over time because of the Dexcool.
Do you have the new style upper radiator hose with the bleed screw located in the tee, if not, order that also before your fails.
A5scott
May 18, 2015 06:34 AM
Danobp
Jun 3, 2014 04:15 AM
eaglewing
Apr 16, 2011 11:06 AM
DooDer
Jan 12, 2010 10:46 PM
barranr
Jun 3, 2007 06:36 AM
