Oil Pump Problem VIN Search
Old Jun 14, 2017 | 10:57 PM
DFMAGuy's Avatar
5th Gear
Default Oil Pump Problem VIN Search
New Member Question ...
How does one go about determining if a 04' Disco II SE7 VIN is "outside" of the Oil Pump Concerns that I gather were predominately in 03' models ?
Thanks.
Old Jun 15, 2017 | 05:58 AM
coors's Avatar
Thanks.
it's 2017. I can say with confidence, if the motor is still running I wouldn't be concerned about it. Mechanical fails were seen soon after production in the earlier days of 2003. IIRC.
search for "death vin" There are a handful of historical threads here containing lists of VIN numbers on the naughty list, but again even if you find a Rover with a running engine on the road today, you shouldn't worry about it. Either the pump has been replaced or it's a unicorn.
Old Jun 15, 2017 | 07:27 AM
Alex_M's Avatar
Frankly, the bin range doesn't matter anyway. The ones that went went super early. Like 15-20k miles. The fact is that all these trucks like to eat oil pumps. If you've got one that's at 100k miles you should replace the oil pump. They're pretty cheap through Lucky 8. Id also replace it any time I had the front cover off for any reason. I just consider it a maintenance item.
Old Jun 16, 2017 | 07:45 AM
CollieRover's Avatar
Thanks.
like the previous posters said, it wouldn't have lasted this long. For peace of mind, maybe bring the vin to a LR dealership or call one, and have them check and see if the engine was replaced.
Old Jun 16, 2017 | 07:53 AM
Best4x4's Avatar
Yep the 03 D2 Oil Pump issue is a thing of the past unless you find an 03 in a tomb with 1-5k on it.
Old Jun 16, 2017 | 07:56 AM
This sounds like a good Tom Cruise movie.....
Old Jun 16, 2017 | 02:11 PM
Mskembo's Avatar
There are good Tom Cruise movies?
Old Jun 16, 2017 | 04:58 PM
Best4x4's Avatar
I liked Live Die Repeat & Oblivion
ruffram
Dec 13, 2021 03:44 PM
boris_gti
Oct 5, 2011 10:28 AM
ciocc
Oct 28, 2010 11:36 PM
00&04 Disco
Oct 9, 2010 05:22 AM
wardo
Mar 8, 2010 03:08 PM
