Oil Pump and Timing Chain Replacement Write Up
#3 posidrive it the corret bit needed for the pump cover iirc.
I've actually already got a 180 stat. It's a Motorad unit. Before you say anything, I put it in before I knew that they were hit and miss. This one performs perfectly, so I must've gotten lucky, but I'll be doing the inline mod in the future along with a more detailed write up than the one already given. With full credit, of course.
Yea, surprised me too drow! The front cover and the oil pump were both in perfectly pristine shape.
Quite welcome! I'll tell you, just replacing the water pump is a lot less work and many fewer steps. That can be done by only removing the fan, serpentine belt, water pump pulley, maybe the idler pulley (but I don't think so, not sure without looking at it), and then you would be able to remove the water pump. Definitely a good idea to do the oil pump as preventative maintenance if you're over 100k though. If you run into any issues, just come by and drop a question!
Thanks Drow, I didn't remember off hand. I'll add that in.
Hey thanks Alex, I'm about to pull the Disco in the garage to replace the water pump. In terms of time and materials would it be worth it to go ahead and replace the Oil Pump and Timing Chain? To this point I don't think I've had problems that would necessitate replacement, I wasn't sure if the oil pump/timing chain combo was one of those 'if it ain't broke...' things?
I am doing the same thing. Went back and forth and figured its not too much more in parts and I have it apart already so why not. I am almost to 100k but staying ahead of the maintenance curve.
The following 3 users liked this post by Joemamma1954:
One thing I started doing was keeping visqueen around, and last time I drained the coolant I placed a large sheet of visqueen under the truck, bunched up around the edges. It made like a pool so that all the coolant was trapped inside. After, I pulled out the visqueen and poured all the coolant into a tub. None (or not much) hit the floor. Other times I had a plastic shallow tub underneath with visqueen beneath. Much easier than cleaning cement.
