Oil sump tightening order
Old Jan 9, 2015 | 04:46 PM
golgafrinch's Avatar
Default Oil sump tightening order
I get the order for all the bolts holding the sump. But, the RAVE doesn't say anything about the ones that connect to the bell housing. Do I tighten these first? I would imagine they pull against the others. If even a little bit.
Or should I torque the others first, then the vertical ones?
Old Jan 9, 2015 | 07:36 PM
Kenso's Avatar
I would tighten the bell housing bolts last. Seems to me that tightening them first could interfere with the rear of the pan seating fully against the gasket/block along the back end of the pan.
Old Jan 11, 2015 | 07:48 PM
TRIARII's Avatar
From the Discovery 2 workshop manual:
Old Jan 11, 2015 | 08:26 PM
coors's Avatar
Don't over think it. Follow the Order specified in the RAVE. Then, hit the bell housing bolts (16ft/lbs). Don't forget the Permatex
Old Jan 13, 2015 | 02:53 PM
Done and done. I did the sump bolts first. Then the bell housing bolts. And used some very thin ultra black permatex all around. So far so good.
tito5590805
Apr 28, 2020 12:53 AM
powderhound
Apr 11, 2015 11:40 PM
knightmetro
Jun 10, 2014 02:49 PM
mike111
Jun 2, 2014 08:58 AM
mx930
Dec 30, 2008 08:08 PM
