Ok, what's missing here
Old Feb 7, 2016 | 11:57 AM
Shoebox's Avatar
8th Gear
Default Ok, what's missing here
Hi, we just purchased our a '04 Disco SE and I decided to spend the day getting to know it, and as I was looking underneath it, and saw this opening, can anyone of you guys tell me what should be there and what it is called so I can get a new one. Pics are attached. The area is behind the oil pan.
Attached Thumbnails Ok, what's missing here-plug-2.jpg   Ok, what's missing here-plug.jpg
Old Feb 7, 2016 | 12:48 PM
Alex_M's Avatar
That's your flywheel inspection hole. There's one on each side. It's supposed to have a rubber plug over it. I'd suggest contacting Abran or Paul Grant for a set so your flywheel doesn't end up catching any rocks.
Old Feb 7, 2016 | 01:32 PM
Shoebox's Avatar
8th Gear
Default That was fast - do you know what this plug goes to...
should I be concerned? pic attached. I found it near passenger firewall.
Alex-M thanks for the fast response.
Old Feb 7, 2016 | 01:52 PM
Alex_M's Avatar
I wouldn't be concerned, just be sure to get a new one. If your flywheel does catch a rock that's gonna be a really bad time.
As for that which you just found, that's a wheel speed sensor plug. There should be a female end that looks just like it somewhere around. Just fond it and plug them back together. You probably have the 3 amigos illuminated since its unplugged. If they have been on long enough then you'll need a special scanner like an ABS Amigo to clear them. Otherwise your ABS and traction control will not function.
Old Feb 7, 2016 | 03:22 PM
abran's Avatar
That is an ABS sensor plug. You should have an ABS fault
Old Feb 7, 2016 | 03:44 PM
jbarr89's Avatar
unless it's been updated with the hard-wired sensor and someone just left the old wiring there
Old Feb 7, 2016 | 08:39 PM
Shoebox's Avatar
8th Gear
Thanks, I have no ABS faults showing up, and I cannot locate the other end to the plug anywhere. So like jbarr89 said its probably a left over.
Old Feb 7, 2016 | 10:35 PM
Dave03S's Avatar
have you made sure the bulbs in your dash have not been disabled?
Old Feb 7, 2016 | 10:59 PM
Joemamma1954's Avatar
Get a code reader that reads all codes including abs and find out for sure.
Old Feb 7, 2016 | 11:29 PM
Alex_M's Avatar
Or if you don't want to drop the cash on that then pull the instrument cluster apart and check the bulbs for tape, paint, or from having actually been removed.
