One problem fixed, one added!
I replaced my front passenger door actuator with a used unit from eBay. Tested it and it works great! Now my door will lock and unlock with the remote!
When I was putting the door back together, I tested the window opening and closing and now I have a problem there. How do I realign the window frame? I figure I need to loosen the entire frame (5 bolts) and manually move the window up and down until I can do it without and resistance. Is there another way?
Thanks!
Thanks!
UPDATE -- The job was completed earlier this afternoon. The window problem came about because I installed the longer T40 screw on the latch side of the window frame. I didn't realize that the two T40 screws were different lengths, but thankfully after we removed the frame for the second time the error was identified.
I have one more latch to fix (rear cargo door), but I may do that after I change the front prop shaft.
resqguy77
01-19-2007 02:40 PM
freewheelin
09-18-2006 08:39 AM
