One problem fixed, one added!
Old May 27, 2012 | 10:49 PM
NT_RoverII's Avatar
Default One problem fixed, one added!
I replaced my front passenger door actuator with a used unit from eBay. Tested it and it works great! Now my door will lock and unlock with the remote!
When I was putting the door back together, I tested the window opening and closing and now I have a problem there. How do I realign the window frame? I figure I need to loosen the entire frame (5 bolts) and manually move the window up and down until I can do it without and resistance. Is there another way?
Thanks!
Old May 28, 2012 | 04:36 PM
NT_RoverII's Avatar
UPDATE -- The job was completed earlier this afternoon. The window problem came about because I installed the longer T40 screw on the latch side of the window frame. I didn't realize that the two T40 screws were different lengths, but thankfully after we removed the frame for the second time the error was identified.
I have one more latch to fix (rear cargo door), but I may do that after I change the front prop shaft.
Old May 28, 2012 | 07:10 PM
Transmission (prop shaft failure) costs a lot more than a stuck back door.....
Old May 28, 2012 | 07:26 PM
NT_RoverII's Avatar
Agreed! I'm placing my order for the front shaft on Wednesday.
shaneb
Jan 28, 2009 08:44 PM
aircraftguy
Nov 15, 2008 08:37 PM
DylanGarcia
Defender
Aug 31, 2007 09:18 PM
resqguy77
Jan 19, 2007 02:40 PM
freewheelin
Sep 18, 2006 08:39 AM
