One tail light not working - bulb okay
2003 D2 passenger side tail light is not working. Brake light works on both sides and driver side tail light works. Signals, headlights, fog lights all fine. Any suggestions for what may be the issue would be appreciated. I’ve changed the bulb out to new so it isn’t the bulb.
I had a similar situation years ago. I don't recall whether it was a tail light or a front parking light, but there was corrosion inside the bulb socket.
I recommend you take out the tail light assembly and carefully inspect it for corrosion.
Glad to hear it was that simple. But ...
Fuses don't blow for no reason. Don't want to rain on your parade, but there may still be a short that occurred randomly. If this problem reoccurs it will likely require more time consuming diagnosis of the circuit using a multimeter.
I hope for your sake that's not the case. Good luck.
Interesting. I've not seen that, and I'm not saying its not possible, but I don't understand what would cause that to happen.
Regardless of that, I'll keep my fingers crossed that Bcrane's truck is good to go and the fuse does not blow again.
cobbcj7
Jul 15, 2013 08:19 PM
