One tail light not working - bulb okay
Old Dec 10, 2023 | 02:32 PM
Bcrane's Avatar
8th Gear
Default One tail light not working - bulb okay
2003 D2 passenger side tail light is not working. Brake light works on both sides and driver side tail light works. Signals, headlights, fog lights all fine. Any suggestions for what may be the issue would be appreciated. I’ve changed the bulb out to new so it isn’t the bulb.
Old Dec 10, 2023 | 05:02 PM
mln01's Avatar
I had a similar situation years ago. I don't recall whether it was a tail light or a front parking light, but there was corrosion inside the bulb socket.
I recommend you take out the tail light assembly and carefully inspect it for corrosion.
Old Dec 10, 2023 | 05:12 PM
Bcrane's Avatar
8th Gear
Thanks for your reply. I plan to pull the tail light and check it and the wiring assembly that connects to the tail light and see if I can see any issues.
Old Dec 10, 2023 | 07:35 PM
Bcrane's Avatar
8th Gear
Light assembly looked fine and tested okay. Checked Rave for the wiring diagram and that tail light is fed from fuse 33 which was blown. Replaced and all is working.
Old Dec 10, 2023 | 09:08 PM
mln01's Avatar
Glad to hear it was that simple. But ...
Fuses don't blow for no reason. Don't want to rain on your parade, but there may still be a short that occurred randomly. If this problem reoccurs it will likely require more time consuming diagnosis of the circuit using a multimeter.
I hope for your sake that's not the case. Good luck.
Old Dec 11, 2023 | 01:41 PM
Harvlr's Avatar
Min, I’m not wanting to contradict you, but 20+ year old fuses do occasionally blow for no apparent reason. If it blows a second time you need to figure out why.
Old Dec 11, 2023 | 03:43 PM
mln01's Avatar
Interesting. I've not seen that, and I'm not saying its not possible, but I don't understand what would cause that to happen.
Regardless of that, I'll keep my fingers crossed that Bcrane's truck is good to go and the fuse does not blow again.
Old Dec 11, 2023 | 04:55 PM
mollusc's Avatar
Fuses become fragile over time through multiple cycles of heating and cooling.
Trailmix
Nov 6, 2023 04:46 PM
robertrankin
Sep 13, 2022 07:13 PM
cobbcj7
Jul 15, 2013 08:19 PM
jonw118
Oct 22, 2010 09:28 PM
fitch11
Oct 24, 2007 09:04 PM
