Original D2 Lug Nut question
Old Aug 12, 2013 | 06:54 PM
microbc's Avatar
Default Original D2 Lug Nut question
I have been searching the forum but couldn't find a definitive answer.
If I take the covers off of the factory lug nuts, can I then use them this way (without the covers?
I have some that are stretched/damaged and was wondering if I removed all the covers (for a uniform look) would they be OK to use this way?
Thanks!
Old Aug 13, 2013 | 06:26 AM
drowssap's Avatar
yes it would
Old Aug 13, 2013 | 08:19 AM
They will look terrible, go buy some good used one's from Paul Grant then start using the correct socket size nut so you don't damage any more.
Old Aug 13, 2013 | 08:57 AM
ZGPhoto's Avatar
Originally Posted by Disco Mike
They will look terrible, go buy some good used one's from Paul Grant then start using the correct lug nut so you don't damage any more.
Lug wrench
Old Aug 13, 2013 | 09:11 AM
Jawbox's Avatar
I don't think the problem is always the Lug Wrench, I've got the exact right socket, but I find moisture gets under the thin cap and rest starts deforming it so that the socket doesn't fit right anymore. I don't think there's a good solution though since the lug nuts are pretty unique from what I've seen.
Old Aug 13, 2013 | 10:34 AM
drowssap's Avatar
there is a post a few up with a link to solid chrome nuts on ebay
Old Aug 13, 2013 | 03:05 PM
microbc's Avatar
Thanks for all the replies.
So they will work (if I can find the correct size lug wrench) and will look ugly (don't really care as my Disco is bed liner painted on the roof and hood).
Mike, I did not damage them and being a 2000 they have held up pretty well over the years.
The tire shop I used, American Tire screwed up some of them and now I either need to spend the $$ on replacements or go the cheap way and remove the caps.
Anyone know what size socket I would need with the caps removed?
Old Aug 13, 2013 | 08:17 PM
dgi 07's Avatar
If I'm not mistaken, 1 inch socket...
Classic89
Apr 22, 2020 03:05 PM
mattmo78
Mar 29, 2013 11:06 AM
DiscoBlanco
Sep 20, 2011 08:50 PM
AK Rover
May 22, 2009 11:38 AM
farley5150
Feb 20, 2005 11:17 PM
