Over pressure coolant - 10K on heads
Old Nov 3, 2020 | 06:39 PM
attworth's Avatar
Default Over pressure coolant - 10K on heads
Good evening folks. I’ve been having an over pressure issue. Coolant is being blown out the overflow hose.
I have about 10k on my rebuilt heads and gaskets, 15k on the fan clutch, fan, thermostat, radiator and hoses. I have no perceivable coolant in the oil, no codes, no white smoke. The thing runs great currently, and other than an evap leak several thousand miles ago, it’s been good.
I noticed the issue when I hit 217* on my ultra gauge, pulled over and realized what was happening. Also of note, on the highway, it’ll stay at 183-188, but after exiting that seems to be when it decides to purge.
I’m likely going to dig into the heads again next weekend, but figured I’d ask the experts here if there’s something else I should be looking at.
Thank you!
Old Nov 3, 2020 | 06:56 PM
redwhitekat's Avatar
I would do a pressure test on cooling system
replace your expansion tank cap
Old Nov 3, 2020 | 06:57 PM
Hysteria's Avatar
An easy and decisive test is to check your coolant for combustion gas with a kit, that will give you a direction to go. It sure sounds like a blown head gasket, but it would be pretty frustrating to misdiagnose such a major repair.
Old Nov 3, 2020 | 07:06 PM
attworth's Avatar
Yes sir I did that last week.
Old Nov 3, 2020 | 07:15 PM
attworth's Avatar
Good call, I just ordered a kit on Amazon. If it’s not the HG, I’m assuming some sort of blockage? Heater core seems to be the common issue, but my heat has been working fine.
Old Nov 3, 2020 | 07:18 PM
Hysteria's Avatar
Either a blockage that the pump is fighting against and building up pressure, or you are boiling your coolant for some reason.
Old Nov 4, 2020 | 10:23 AM
Richard Gallant's Avatar
Yea that is exactly how mine was with the crack in the gasket, fine at highway speed then it would purge as the engine heated up. You may get no good result with combustion kit, I did not but the gasket was in fact shot.
One other thing my heads were seriously warped when I pulled them they could not be trued. I replaced them and had the new set trued.
  • You can bypass the heater core to rule that out.
  • Check the return line from the rad to the expansion tank make sure it is clear
  • You can do a cooling system flush with plain water from a hose that should show up any issues with blockage
  • Also thermostat check that it actually opens
For the combustion test I would try this:
  • Have the test kit ready to go
  • Loosen the rad cap so the system will not pressurize.
  • Go for a short drive around the block to get the system up to temp
  • Pull the driveway
  • Pull the cap and test
Maybe you will have better luck than I did with test kit
Old Nov 4, 2020 | 06:47 PM
Extinct's Avatar
95% chance you have a small hg leak. It will get bigger over time.
If you run the inline thermostat mod with the cap one turn loose and it is full of coolant, it will not overheat (assuming the radiator is fine). It will drink coolant, and you will have to top it up occasionally.
I have had probably a dozen trucks with blown hg. The gas test does not always show it is blown. More reliable test is coolant leakage over time, or pressurization of the cooling system. If it is being pressurized, hg is blown.
Good luck, let me know if you have specific questions.
Retroman1969
Jun 20, 2014 10:53 PM
bbeismann
Feb 1, 2013 10:22 AM
Infrno
Mar 22, 2012 10:41 PM
jonmyke
Freelander
Dec 24, 2010 09:08 AM
karmannbee
Dec 23, 2006 10:07 AM
