Overheating
Old Aug 2, 2018 | 09:23 AM
collector87's Avatar
Default Overheating - coolant in cyl. 3
Hello,
Started to overheat, took into shop - head gasket job went well. Still overheating - after lots of testing found coolant in cylinder 3 at spark plug. Going to swap block with one from my parts truck.
Wondering:
1. How close will this be to my rear main seal - I've been losing oil there for years and would like to replace it if it's close.
2. Is there anything else I should get done at the same time we're doing this?
Thanks!
TDC
Old Aug 2, 2018 | 09:33 AM
CollieRover's Avatar
If you have the block out you will have access to the Rear Main Seal I believe.
Sixpack577
May 9, 2023 09:36 PM
andrewgib
May 20, 2019 08:57 AM
Sixpack577
Jun 17, 2018 08:57 PM
mdfud
Dec 9, 2012 11:17 AM
Ozzy3313
Nov 29, 2012 12:59 PM
