Overheating Issue
Old Jun 22, 2019 | 12:15 AM
Triddell62's Avatar
Default Overheating Issue
I just changed the head gaskets, water pump, and thermostat and after about 5 to 10 min of driving it starts to overheat. I used stopleak before replacing it so I'm not sure if that managed to clog the radiator. There is no coolant leaking and I'm the coolant level stays the same.
Not sure what else it could be, any ideas?
Old Jun 22, 2019 | 01:31 AM
Dave03S's Avatar
The stopleak is no good for the radiator that is for sure. However, air in the system is the most common cause. Fully bleeding the system can be more of a challenge sometimes. What method did you use? One way to determine if all the air is out is to open the bleed screw when the engine is stone cold, in the morning. If you can add any coolant into the bleed hole, then you have displaced a small quatitiy of air. Do this every morning until you can no longer add any coolant. If that doesn't help, then fully flush out your entire system, rebleed and recheck the bleed hole cold.
Old Jun 22, 2019 | 09:45 AM
Triddell62's Avatar
I opened the bleed screw then lifted the reservoir above the engine and added coolant till it came out
Old Jun 22, 2019 | 10:48 AM
Best4x4's Avatar
Repeat that about 3 times
Old Jun 25, 2019 | 04:13 PM
Triddell62's Avatar
I bleed it and it is still overheating. I have a cheap thermostat so that may be the problem but I really dont know
Old Jun 25, 2019 | 10:12 PM
Triddell62's Avatar
Turns out the water pump hose and upper hose were on reversed so that was the problem
Old Jun 26, 2019 | 07:01 PM
shanechevelle's Avatar
This is probably common with all the people overheating here. Lolololol.
Sixwinged
Jul 5, 2016 09:13 AM
stb616
Dec 2, 2014 09:40 PM
pilsner
Jun 5, 2012 11:24 AM
christianmotox
Mar 12, 2010 10:31 AM
ryanswindell
Oct 1, 2009 03:38 PM
