Overheating and Pressurized cooling system...
Old Jun 4, 2015 | 06:22 AM
drowssap's Avatar
not a liner bearings
Old Jun 4, 2015 | 09:13 AM
Motorhead1's Avatar
Wow, $1280 for a 3k cap? Thats a terrible deal. Now you have a Disco with a head gasket issue and a knocking engine....those ba$tard$. Get all you can then
Old Jun 4, 2015 | 10:20 AM
abran's Avatar
Agree with Drowssap, connecting rod bearings. Sounding like a diesel is not a slipped liner. Every tech says slipped liner when they hear a noise, especially the dealer. Most of the techs at the dealer were not trained on discovery motors and are guessing.
If it hasn't been doing the knock for long you might be able to just swap the bearings.
Did the vehicle run well for any amount of time after purchase?
With bearings I would suspect you have low oil pressure, is the oil light on? Also if there is coolant in the oil? The coolant can eat the bearings away.
With the knock and head gasket you are looking at a healthy bill.
Also, you could post a video of the noise if you want a 15th opinion.
Good luck.
Old Jun 4, 2015 | 03:11 PM
drowssap's Avatar
the motor had an issue from day 1,you bought it leaking coolant.
it may have needed head gaskets at one time but you are beyond that point now. you basically need a engine.
so I would not be worried about a "cap" I would be worried about how to get the $3k out of them to put toward a used engine.
because driving it over heated is what burned up the bearings, so you wont want to admit that to your warranty company.
I'm not try to be the voice of doom, but someone has deal with reality.
Old Jun 7, 2015 | 01:48 PM
kmccarthy88's Avatar
4wd High
Doom and gloom huh? I pulled the spark plugs, four were white the 4, 6, 8, and 1.
I tried K&W HG sealer, what a waste of my time... It worked until I tried driving.
Old Jun 7, 2015 | 03:38 PM
RoverMasterTech's Avatar
Junk it. Buy a Honda.
Old Jun 7, 2015 | 06:56 PM
4wd High
I owe $$$ in it...
mmaesner
Apr 1, 2015 06:31 PM
discorey
Nov 27, 2014 12:47 AM
kdscott100
Aug 22, 2014 02:51 PM
Frank4
Mar 18, 2010 08:13 PM
boilerman
Nov 12, 2008 07:35 AM
