oxygen sensor
[/quote]ORIGINAL: riden686
thanks spike555, i am hopeing to get above my best mpg which was only 13.3, iallreadybuy premeium,i might fill up at shell next time and see if i can inprovesome. is there any other gs tips i can use on myDisco.
I get the exact mpg you get in my 94 Disco. I just put in a can of BG 44K in the tank and filled up today. I drove it for a while. After I run the BG through it I'll put in 3 oz of Redline cleaner in each tank. Hopefully this and working on the list that Mike gave us will help with the mpg's.
ORIGINAL: cptshanman
Did I hear you guys right that all four O2 sensors are the same? Why have different part numbers in that case?
Shannon
Shannon
If you have it it takes one set of O2's, if you dont it takes a different set.
