I have my disco running but this p-0441 code has come up.
Is there a starting point on fixing this? I have done the basics.
Checked all accessible vacuum lines.
Reason: incorrect code #
On a D2 this is a test fault where the system has noticed that there is no purge flow through the evaporative canister valve. If you clear the code, it may return in two driving cycles. You can find out more in the RAVE workshop manual under emmissions.
thanks for this info
will try and work through it.
Looks like it could be the purge valve at the canister.
Before reading this I thought it could be the upper purge valve.
