P code 441?
I have my disco running but this p-0441 code has come up.
Is there a starting point on fixing this? I have done the basics.
Checked all accessible vacuum lines.
On a D2 this is a test fault where the system has noticed that there is no purge flow through the evaporative canister valve. If you clear the code, it may return in two driving cycles. You can find out more in the RAVE workshop manual under emmissions.
DiscoBenjamin
Oct 14, 2011 05:53 PM
