P0174 and P0171
Old Dec 30, 2020 | 01:14 PM
Rok2d's Avatar
4th Gear
Default P0174 and P0171
99 Disco II - Los Angeles, CA
106k, rebuilt heads, lifters, timing chain, oil pump, 180 stat, rotella 15-40
Getting the P0174 and P0171 combo, Mixture adaption Factor FRA. I am testing the fuel pressure as i suspect the fuel pump to be going out or a leaky injector. My question is what values should i be getting. Is there a value for position 2 on ignition and another value for running etc? I've looked at the RAVE and just see the 50psi running. I'm trying to rule fuel pump injectors out before i smoke test it. Does this sound like the appropriate sequence or do you all have a different suggestion.
thanks!
TC.kenya
Jul 10, 2011 08:43 AM
dev99disco
Sep 10, 2010 06:11 PM
possibly owner
Oct 16, 2009 01:56 PM
lasertech
Aug 15, 2008 12:07 PM
houstonhelix
Mar 27, 2008 08:04 PM
