P0308 code misfire #8 and oily spark plug
Old Feb 10, 2012 | 10:20 PM
GARovee's Avatar
100+ psi is okay... 120-145psi is great. Less than 100 is either done wrong or the cyl is trash. Less than 100 is either worn rings or leaking valves.
Old Feb 13, 2012 | 11:57 AM
Summitdog's Avatar
Disco Mike, I did another compression test on #8 with about 4 revolutions and get 140psi.
RatisJ100,
To do a compression test you will need a compression gauge screw it into the cylinder that is in question, then unplug the inhibitor switch located passenger side firewall (this will cut off gas so you can turn ignition without starting) then turn the key till the cylinder builds up compression.
Old Feb 16, 2012 | 04:06 AM
ratijs100's Avatar
RatisJ100,
For inhibitor switch do you mean Inertia Switch for fuel cut-off? In RAVE I could not find any inhibitor switch connected to fuel system. Only inhibitor switch I found was connected to transmission.
Old Feb 16, 2012 | 04:24 AM
Yes, the inertia switch. Or pull relay #1 in underhood box, the fuel pump relay, or fuse 10 in same to disable the pump.
Old Feb 16, 2012 | 09:20 AM
Summitdog's Avatar
I'm trying not to jinx myself but I did seafoam in the oil, gas and vacuum lines and so far so good.
Yes I meant Inertia switch!
adolfojbonilla
Sep 24, 2015 12:07 PM
Kdognportland
Aug 27, 2013 12:35 AM
fund247
Feb 16, 2013 02:22 PM
primey
Oct 26, 2011 07:24 PM
Aquaholic
Feb 3, 2007 10:55 AM
