p0430
p0430
Hello,
I just had a new cat installed on the pass side along with gaskets to fix some leaks at the manifold to pipe joint. I was getting code P0430 before and I still have it. Will this code clear itself or do I have to clear it. I've gone about 80 miles since I had this installed.
Thanks,
Steve
2003 DIscovery
135k miles.
Thanks,
Steve
2003 DIscovery
135k miles.
so mine is not throwing a check engine light but is showing on a code reader p0430? is it not bad enough to throw a code? its saying on the reader Catalyst system efficiency below threshold. do you think a good cleaning of the cat would help. that side ran rich for 2 years due to bad coil. or should i just go for full replacement?
