p1415, p1412
Old Jul 3, 2008 | 08:44 AM
Roveroh's Avatar
Default p1415, p1412
Hey guys, back again.
As a side note my recent 02 sensor issue was solved by crawling under the car and finding that when my mechanic installed my crank sensor, he accidently pulled the leads from the 02 sensor connection. Problem solved.
Now I have these codes. I did some research on the site that lead me to check the resivour on from the secondary air solenoid. Turns out the vacuum line was off. Could this be the issue?
Prior to the chk engine light coming on my wife said when she started it she heard a high pitched whine that lasted a couple seconds. Could the secondary air pump be starting to fail as well?
Old Jul 3, 2008 | 05:45 PM
roverguy7's Avatar
Default RE: p1415, p1412
you got it. the whistle was probably just the air being sucked in by the tube, dont worry about it until it becomes a problem, however, make sure that the vac line to the res is tight, if not, replace the rubber cap with a small rubber tube
Old Jul 7, 2008 | 09:09 AM
Roveroh's Avatar
Thanks- for anyone's future reference tracing the vacuum lines seems to have solved the problem. No more chk engine light and no more whistling.
Torancis_LR
Sep 27, 2015 01:23 PM
bmonkey4201
Oct 20, 2010 08:56 PM
JEFIII
Sep 9, 2010 11:16 AM
96Bronco
Apr 25, 2010 10:44 AM
Torancis_LR
Jun 24, 2009 02:12 PM
