P1590 (ABS roug road signal malfunction) - Right Rear and Left Rear
Old Jul 18, 2022 | 09:45 PM
acg's Avatar
acg
Default P1590 (ABS roug road signal malfunction) - Right Rear and Left Rear
I went wheeling for 3 days with the BC Roverlanders group. Got the P1590 (ABS roug road signal malfunction) code on the first day. The code came on after we went through a few deep mud holes.
The Nanocom was showing two fault codes:
- Rear Right outlet valve open circuit (intermittent 15 times)
- Rear Left sensor electrical failure (6 times)
I am getting these check lights on the dash:
- Brake
- Hill Descent Control
- ABS
I understand my situation is not the 3 amigos, ie., HDC, ABS, TC. I do not have a TC check light.
Since the Nanocom is saying it is both a rear right and left left issue..... I am wondering if there is some sort of module that is receiving signals from both rear right and rear left ABS sensors.
I will be washing off the mud and crud tomorrow. I searched the forums and cannot find anything similar to my problem. Does anyone have any ideas on what may be casuing the problem before I tear into this problem?
Thanks!
Old Jul 28, 2022 | 04:22 PM
acg's Avatar
acg
Update:
It appears to be an ABS sensor shim issue. I had recently switched to an aftermarket hub before I encountered the engine check code. The supplied ABS sensor was finicky.
DiscoveryWes
Feb 9, 2020 08:23 AM
adolfojbonilla
Oct 11, 2019 07:32 PM
mcaramb
Oct 9, 2017 11:57 AM
Bigmonty
Aug 6, 2007 11:13 PM
rebooTT
Jun 20, 2005 01:09 AM
