P1590, p0327, p0430, p0150, p1174, p0174
Old Sep 30, 2013 | 08:08 PM
garyjames84's Avatar
5th Gear
Default P1590, p0327, p0430, p0150, p1174, p0174
Need some help guys, and I just joined this forum so forgive me if this topic has been answered before.
I have a 2003 land rover discovery II with 111,000 miles that I bought last year and I was needing to take it in to get an inspection, but of course couldn't because of the codes listed above. I researched some of these codes, but I couldn't even tell you where to start as far as fixing the problem. Any advice would be great...once again I'm far from a mechanic so go easy on me guys and laymen's terms preferably. Thanks.
Gary Gostnell, MAT, ATC, LAT
Athletic Trainer
SporTherapy, PC
Physical Therapy & Sports Medicine
Fort Worth, TX
sportherapy.com
Old Sep 30, 2013 | 09:15 PM
1590 - error signal from SLABS unit (search for three amigos)
0327 - one of your knock sensors is unplugged or dead
0430 - right hand catalytic converter no longer efficient, may need new one
0150 - front right hand OI2 sensor outside of spec - replace both
0174 - right hand bank lean (most likely O2 sensor, could also be vac leak)
1174 - right hand bank lean and computer cannot compensate
The shop manual is called the RAVE, and is a free download below. About six lower lumbar strains and you'll be able to afford the mechanic.
Old Sep 30, 2013 | 09:51 PM
5th Gear
Thanks. This looks like there isn't going to be an "affordable" way around this is there?! I'd take 6 lumbar strains if it'd pay for my bill!
Old Oct 1, 2013 | 01:16 AM
I did not want you to have the strains, just help guys get well from them. Been there, done that, got the T shirt.
Old Oct 1, 2013 | 11:43 AM
5th Gear
Fair enough. Do you remember what lumbar level that you strained? L1, L2, L3,L4, L5? Multiple levels? They can be tedious because you're constantly utilizing those muscles for stabilization.
I researched on O2 sensor replacement and it looks like it can be done if I try. Any advice on what tool to use? Crescent wrench or the actual O2 wrench?
Athletic Trainer
SporTherapy, PC
Fort Worth, TX
sportherapy.com
Old Oct 1, 2013 | 11:52 AM
dusty1's Avatar
for o2 it is a good idea to let it soak a bit in some break free junk, they can sometimes be pretty stubborn. I use PB blaster
Old Oct 1, 2013 | 12:09 PM
5th Gear
Gotcha. What tools did u find the most useful? The dealership was charging $200 per sensor and were trying to make it sound like it's tough to do...I assumed they just wanted to make an extra buck. I'm all for getting business, but at least be honest. They also charge $135/hr for labor. Yikes.
Old Oct 1, 2013 | 12:18 PM
dusty1's Avatar
o2 wrench is ideal. there is the higher risk of stripping with an open end. That being said, I have used an adjustable wrench without incident.
Old Oct 1, 2013 | 12:39 PM
5th Gear
3/8 or 1/2 for the O2 wrench? I've heard yes's for both actually.
Athletic Trainer
SporTherapy, PC
Fort Worth, TX
sportherapy.com
Old Oct 1, 2013 | 04:50 PM
Amen on the PB Blaster.
And mine was multiple, and I have a DVD of the MRI, which proves I'm not the spineless skunk many believe.
jallen9
May 8, 2013 12:24 AM
baburhan
Sep 20, 2010 02:42 PM
richief556
Aug 5, 2010 09:08 AM
787tech
Jul 9, 2008 02:43 AM
hriant88
Apr 30, 2008 07:33 AM
