Panhard rod Conversion
Old Jun 19, 2013 | 08:04 PM
ZGPhoto's Avatar
Default Panhard rod Conversion
Who's done it? I'm referring to taking out the watts linkage and having a panhard rod welded in instead? I'll be doing it this summer and wanted to hear unbiased opinions on it.
This is the kit I'll be using:
Panhard Kit - RuffStuff Specialties
Old Jun 19, 2013 | 09:18 PM
May I ask why you want to do this, probably because of a lift. If that is the case, go to RTE and look at their solution to modify the watts set up.
Old Jun 19, 2013 | 09:30 PM
ZGPhoto's Avatar
It's really for the most articulation, about 3-3.5" of lift. The RTE setup is nice but watts bushings will still fail over time and I haven't seen a lot of negatives on the panhard setup. This truck is becoming less and less road used, and if I'm going to spend $300 doing something, I'd rather get the biggest benefit off road.
Old Jun 19, 2013 | 09:36 PM
Fivespddisco's Avatar
I have never done it but I don't see why it would not work.
Old Jun 20, 2013 | 08:31 AM
ZGPhoto's Avatar
You know Don Trudeau, right Justin? He did it with his truck and has had pretty good results so far.
primussucks
Feb 20, 2014 08:11 PM
coors
May 2, 2013 01:22 PM
coors
Jan 30, 2013 02:25 PM
JPSpen
Oct 15, 2012 10:51 AM
moomoo
Jun 16, 2011 08:20 PM
