Parking brake adjustment
Parking break has gotten soft recently. It still works, but I have to pull the lever ever higher.
Anyway, I followed the Rave manual and climbed underneath to adjust the tensioner at the drum. I craned it tight, then loosened it 1 and 1/2 turns as per procedure. That didn't seem to help.
I then went to Phase 2 and removed the console switches.
The manual tells me to look for an adjustment screw to tighten the cable.
I can see the cable and where it passes through a metal thingie of some sort, and there's a rubber "cone" at the top...but I don't see anyway to adjust it.
There should be something obvious there, but I don't see it.
Anyone have a picture or can give better instructions than the manual?
Thanks.
Thanks.
bcolins
03-08-2015 07:14 AM
tibyABv6
12-18-2012 10:09 PM
