Parking brake adjustment
Old Oct 22, 2009 | 10:34 PM
meltdowndave's Avatar
Default Parking brake adjustment
Parking break has gotten soft recently. It still works, but I have to pull the lever ever higher.
Anyway, I followed the Rave manual and climbed underneath to adjust the tensioner at the drum. I craned it tight, then loosened it 1 and 1/2 turns as per procedure. That didn't seem to help.
I then went to Phase 2 and removed the console switches.
The manual tells me to look for an adjustment screw to tighten the cable.
I can see the cable and where it passes through a metal thingie of some sort, and there's a rubber "cone" at the top...but I don't see anyway to adjust it.
There should be something obvious there, but I don't see it.
Anyone have a picture or can give better instructions than the manual?
Thanks.
Old Mar 12, 2012 | 02:34 AM
FlyingZebra34's Avatar
I'm having this same problem and I guess no one resolved it, any help?
Old Mar 17, 2012 | 02:59 PM
BMF175's Avatar
Cool
bump.....
Old Mar 17, 2012 | 09:08 PM
Well now my parking brake handle itself seems to be broken. The spring seems to be missing or worn down. When I press the button down it wont come back up.
parkerlander
Feb 18, 2013 10:44 AM
tibyABv6
Dec 18, 2012 10:09 PM
shawn
Sep 23, 2007 06:46 PM
psg
Oct 2, 2005 02:07 PM
