Part needed.. are these that hard to come by?
New or Used they are still out there it just depends what you want to spend. ![Cheers](https://landroverforums.com/forum/images/smilies/cheers2.png)
OR go with a Universal Kit.
> https://www.roversnorth.com/parts/yj...ng_battery_dii
> https://www.ebay.com/itm/LAND-ROVER-...MAAOxy2E1SHi7T
> https://www.roversnorth.com/parts/am...y_discovery_ii
> https://www.ebay.com/itm/New-OEM-Lan...ss!14086!US!-1
If you cant afford Steve Parkers Kits, i found another way to replace the drain tube at the sunroof pan. I used 3/8 PEX brass connectors, cut off one end so it does not hit the sunroof track, then used JB Weld Plastic weld to put them in place. Then i added more JB Weld around the whole plastic piece. Worked great!! i have finished one and total cost was $10 Bucks!! While I was at it I ;pulled the sunroof out and resealed the fram to the body with GE Silicone. That cost another $8.
