Parts for valley pan gasket repair
Old Feb 1, 2014 | 07:26 AM
JoeLena's Avatar
Default Parts for valley pan gasket repair
I see I posted a request in the wrong place and got no replies, so I'll try here, sorry for the duplication.
So I've had this little drip get worse over the past weeks. Coolant drip, drip, drip from rear of engine that slides along the drivers side bell housing and drips off. I used the coolant pressure tester thing and found a couple other minor leaks, but hard to pinpoint this one no matter what I do, just can't see where it originates. From reading others it most likely is the valley pan gasket, or loose bolts.
But to get to the bolts I have to tear a lot down, right?
In the RAVE I assume I need to do the 30:15:08 lower manifold gasket repair, can someone confirm this? I'm not that mechanically inclined, but usually follow directions pretty well to do things.
I was looking at the Atlantic British site, hoping to find a kit of everything needed, but do not see one. Is there a source for the parts needed? I'd like to get it all in advance if I can.
Any pointers on getting what I need sorted out would be appreciated. I have read a few posts that have some good info.
It's a 2004 S model if it matters. Have had the heads done (PO) and nothing else points to a head gasket. UltraGauge always at 194 degrees, oil looks good, etc., so hoping it is the valley pan.
Old Feb 1, 2014 | 07:27 AM
JoeLena's Avatar
I know I'll need the valve cover gasket kit with bolts and all, and obviously the valley pan gasket. Intake manifold gasket, valley end seal, gasket valley end clamp. What other items should be replaced while I have it apart?
Old Feb 1, 2014 | 02:36 PM
marizcal's Avatar
be aware... search and read a little more on the forum and you will find that the leaks in the back of the engine... many time is a head gasket failure... so make double check....
Old Feb 1, 2014 | 03:08 PM
Dan7's Avatar
You definitely want to pinpoint the leak before you start tearing off the top end. Isn't there a coolant dye?
Old Feb 1, 2014 | 03:17 PM
drowssap's Avatar
there sure is black light stuff. but a pressure tester and inspection mirror will usually find it.
jpmiller
Sep 26, 2012 06:32 AM
03discoman
Mar 15, 2010 09:32 AM
JHDisco2
Dec 15, 2009 10:58 AM
chad420
Oct 24, 2009 02:51 PM
JimScream
Jan 6, 2009 02:01 PM
