Passenger door leak
Old Aug 13, 2014 | 12:45 PM
weepit's Avatar
Default Passenger door leak
Left truck outside last night, pouring rain here.
Today I've got a leak above the passenger front door. Not bad but headliner is damp. Suggestions on where to start looking for source? I'm hoping it's not running off from sunroof, they seem good and wetness is only above door frame
Old Aug 13, 2014 | 12:49 PM
abran's Avatar
The sunroof drain pipe runs from the sunroof tray to the top of the door frame on both sides. Most likely a cracked pipe or sunroof tray drain pipe.
Old Aug 14, 2014 | 06:24 AM
drowssap's Avatar
also check the drip rail near the windshield, i believe a read a TSB on that to.
Old Aug 14, 2014 | 10:28 AM
weepit's Avatar
Thanks all.
My headliner is toast too so I can try and fix all together perhaps.
Went to a local headliner guy but he wanted $600 to replace so I will likely do it myself. Looks like a really sucky job...
Old Aug 14, 2014 | 11:46 AM
abran's Avatar
I pay $200 locally to remove the headliner, re cover an re-install.
Find a new headliner guy. For $200 its worth it, $600... not so much.
Old Aug 16, 2014 | 04:51 AM
redrover75's Avatar
Default headliner install.
Where are you?
drowssap
Apr 5, 2011 12:17 PM
Spencerfitch
May 3, 2010 02:56 PM
rgrizzard
Mar 6, 2008 10:16 AM
r1pilot
May 2, 2006 11:22 AM
