Passenger side window not working..
Old Jul 2, 2016 | 08:48 AM
toad2's Avatar
Default Passenger side window not working..
and kind of has me stumped.
No fuses blown.
Plugged in two spare motors, neither worked.
Can hear relay working in BCU.
Swapped wiring at switches, drivers side window works on pass side switch but pass side motor does not work on drivers side switch.
No power at window motor socket.
I am not very good at finding actual wiring in the rave manual so i haven't been able to trace the wiring. But to be honest there are so many harnesses at the BCU i am not sure if i could anyway.
Any help would be appreciated.
Thanks.
Old Jul 2, 2016 | 09:11 AM
matt3502's Avatar
That sounds like it is the switch. Had the same thing. Reach out to Paul Grant, he usually has used ones. Much cheaper than a new one.
paulgrant@mac.com
I have gotten many things from Paul, he is a great resource.
Old Jul 2, 2016 | 09:18 AM
toad2's Avatar
I swapped the switches. Drivers side window worked on the pass side switch. but not the other way around.
Old Jul 2, 2016 | 11:32 AM
matt3502's Avatar
My bad. Your post said swapped wiring.
Old Jul 2, 2016 | 02:09 PM
toad2's Avatar
no prob, wasn't being snarky. hard to tell with my posts sometimes, haha.
Old Jul 2, 2016 | 09:32 PM
disc oh no's Avatar
Do you have power at the switch? If not, see if you have power at the fuse. Sounds like power is not making it through the whole system for that side. You've just got to find where it has power and where it stops. A common problem on a lot of vehicles is wires breaking where they go through the door jamb
twoxred
Oct 4, 2021 07:07 AM
tsuyoi
Sep 22, 2020 10:37 AM
Disco Buddy
Oct 13, 2013 12:58 PM
post42
Sep 10, 2013 03:33 PM
southfloridadiscoII
Oct 21, 2012 06:33 PM
