PCV
First thing is to get that little plastic piece out of the passenger side. Mine was packed with gunk and my valve cover kept leaking. I took the plastic part out completely and test drove it for a few miles. NO MORE LEAKS!!! The back pressure must've been so bad. You can replace the plastic gizmo or take it out and use the Fram PVC valve as stated above.
It's a cheap and easy fix for the crappy plastic PCV.
This is what my plastic PCV piece looked like before I did the PCV mod:
