Pedal mod?
Old Aug 7, 2017 | 10:23 AM
xsramo's Avatar
Default Pedal mod?
I've had my disco for about two months now and so far I really enjoy the truck. I do have a couple gripes about its ergonomics though. The pedal position on the disco is rather central in the footwell which means my leg is pressed against the steering wheel when using the pedals. Also the brake and accelerator are positioned so close together that my foot has inadvertently pressed both pedals a few times. It seems the seat cannot be lowered enough to help mitigate this problem either. I took a look at the pedals and the arms seem to be made of steel...has anyone reshaped the arms so the pedals favor the right side of the footwell? Or does anyone have any ideas that might help alleviate this? Thanks!
Old Aug 7, 2017 | 10:30 AM
Sixpack577's Avatar
Worst case, remove rubber cover, cut off right side of brake pedal. Drill, tap and bolt aftermarket aluminum pedal over stock, offset the new pedal to the left.
That's the only way to gain clearance between the pedals.
I put an aluminum brake pedal on all my vehicles.
Not a fast n furious one that's more slick than the stock rubber cover, but one with some grip.
My foot is always slipping on the stock brake pedal when it's wet. I have placed new pedals slightly left to gain clearnce between the pedals too, works fine.
I've never had to cut or trim a brake pedal any either, but it's doable.
My size 11 shoe isn't that big.
Old Aug 8, 2017 | 08:44 AM
xsramo's Avatar
Hmm I'll have to do some thinking - thanks for the input. I'm not opposed to bolting on new pedals if it gets my leg out from underneath the steering wheel.
Old Aug 10, 2017 | 08:00 AM
JUKE179r's Avatar
Good idea mate! I wear steel toe work boots and I'm constantly tapping the gas and brake pedals at the same time.
Old Aug 10, 2017 | 09:08 AM
Friday Night Disco's Avatar
Am I the only person that uses my left foot to brake??
Old Aug 10, 2017 | 10:04 AM
Sixpack577's Avatar
Doesn't matter when your right foot hangs both pedals.
Old Aug 10, 2017 | 10:13 AM
mollusc's Avatar
Are you a racing driver or someone who drives heavy tracked equipment? They're the only people I know who typically do this.
A5scott
May 28, 2019 07:23 PM
ralphobell
Apr 2, 2014 08:02 PM
Brad S1
Nov 2, 2006 08:10 PM
Durfee
May 14, 2006 04:16 PM
parks
Jan 31, 2005 12:21 PM
