Pending code 1668
Old May 20, 2012 | 11:54 AM
gavone1976's Avatar
Default Pending code 1668
P1668?Just got this pending code,any thoughts,solutions?
Old May 20, 2012 | 12:19 PM
I dont know what that code means and I'm to lazy to Google it for you.
Old May 20, 2012 | 12:31 PM
1668 is a engine anti-theft circuit high, serial link open to circuit.
Old Nov 19, 2012 | 07:32 AM
Slingin Carbon's Avatar
I too just got this code this morning on my UltraGauge... What does this mean?
Old Nov 19, 2012 | 07:57 AM
ihscouts sent this link in - Fault Code P1668
Old Nov 19, 2012 | 08:24 AM
So as long as I start the vehicle within 30 seconds of hitting the open button on the remote, I should be ok! Stupid thing! Driving me crazy already... How is it that it just all of a sudden starts throwing this up? I just drove the thing Fri, Sat and Sun and had no codes and no issues. Then this morning I go to start it and I get the 1668!
I did change Spark Plugs to the Platinum +4's, is it possible that I might have hit something or caused this to happen?
Old Nov 19, 2012 | 10:02 AM
jafir's Avatar
Did you disconnect the battery while changing the plugs? This error will pop up when the computers come online and cannot talk to each other for a couple of seconds.
Old Nov 19, 2012 | 10:33 AM
I did not disconnect the Battery (Really was aware that was required). So is there a way to get this code to reset or go away? I was able to drive all the way to work today without the engine stalling or acting strange. I even stopped at the Gas Station, shut the engine off and then cranked it right up when I got back in.
Old Nov 19, 2012 | 12:50 PM
clanch's Avatar
Most likely a control unit made a phone call, and did not get a answer. Check your battery voltage, and check voltage cranking over. May a low voltage. Since it is a pending code comes under three trip code. Clear it and see if it comes back
Old Nov 19, 2012 | 02:00 PM
I was wondering about clearing it, but I am very hesitant on doing that. I did go out at lunch and it fired right up and I know it was more than 30 secs after I hit the unlock button on the remote. I will check the voltages when I leave work this afternoon.
Thanks for all the info!
film842
May 2, 2015 10:21 AM
sharp
Apr 3, 2014 09:19 AM
jrm123180
Jul 13, 2010 08:54 AM
sparky
Jul 27, 2009 07:41 PM
bcolins
Oct 7, 2008 07:19 PM
