Pending code P0441
Old May 3, 2021 | 09:40 PM
boostedt0y's Avatar
Default Pending code P0441
All,
looking for some guidance on what to look for next to solve my P0441 code on a 04 D2. I searched but didn’t find anything that seemed useful. The code first appeared a month or so ago when I got to about 1/4 tank.
Replaced the purge valve with a Hyundai unit and put in a new oem gas cap. all was well for amount a month. Around 1/4 tank this week I get a pending P0441 code. Not sure if there is a connection between the code being thrown when I reach 1/4 tank. Any idea what could be causing the P0441 code if a new purge valve was recently fitted?
thanks
Carlo
Old May 3, 2021 | 11:04 PM
Discorama's Avatar
LOL, I got the same code just in time for smog. Reading here in the threads, some people report cleaning the gas tank bung with scotch brite the fixed the problem.
I just got a new Hyundai purge valve, hopefully that was the problem. Also the small brass tubing in the intake manifold is lose. I can pull it out easily with the hose of the purge valve. I have to make sit it tight again, otherwise this is a potential intake leak.
Old May 3, 2021 | 11:08 PM
boostedt0y's Avatar
I have you beat. The P0441 code first started on my way to smog the car so that I could register it (out of state purchase)
Old May 4, 2021 | 06:44 PM
Discorama's Avatar
I installed the new purge valve, the brass tubing sit tight and cleaned the gas tank bung. So far no codes. Ordered a new fuel cap, since the gasket on the old one feels quite hard.
Old May 4, 2021 | 06:45 PM
gulfstream69xr7's Avatar
My D2 throws that code about every two weeks or so, if I end up sitting i park in one spot for too long.
Old May 4, 2021 | 09:42 PM
Discorama's Avatar
So I just got a pending P0441 with the new purge valve again. Waiting on the new tank cap.
Old May 14, 2021 | 11:11 PM
boostedt0y's Avatar
An update - I drove the D2 with the pending code P0441 for about a week expecting for the code to materialize into a SEL. Shortly after starting the truck each day, I'd get the annoying alert on the UG of the pending code. However, one morning when I went to drive the truck the pending code alert never materialized on the UG. All has been good so far and I'm crossing my fingers it stays that way.
Disco Britt
Nov 7, 2015 11:28 PM
CaptainCulp
Aug 6, 2014 08:05 PM
TOM R
May 15, 2013 08:36 PM
pixel
Mar 5, 2012 12:29 PM
nashville_disco
Nov 29, 2008 05:03 PM
