Pic: Name that part! (Help ASAP please1)
Old May 17, 2010 | 08:21 AM
Disco2Fever's Avatar
Default Pic: Name that part! (Help ASAP please1)
Hello friends!
We're leaving the state on Thursday, and I need to get a trailer light adapter for our 2000 Rover. It came from the factory with this hook-up, and nobody I've showed it to has ever seen it (including the folks at Autozone).
I either need to have one overnighted today, or find a place locally that has one. In my search, knowing the name of this connection type would be a huge help.
Any ideas, friends?
THANKS!
http://i297.photobucket.com/albums/m...ann/lights.jpg
Old May 17, 2010 | 08:47 AM
kenk's Avatar
http://www.rovahfarm.com/DiscoIBodyElectrical.htm
I was not able to find one locally either. I had to order it. If you call, he may overnight you one(note they dont open 'til noon EST). Trevor is a pretty swell guy.
Old May 17, 2010 | 09:38 AM
XCELLER8's Avatar
go to U-Haul or Ryder rentals......the bigger stores usually stock them..or will have something to replace it
Old May 17, 2010 | 09:39 AM
hilltoppersx's Avatar
folks at autozone never know anything.
Old May 17, 2010 | 01:03 PM
Get a hold of Millbrook trailers on 68th St and US131, that is a trailer light plug, also here in Grandville there is Grandville Trailer on 28th St and Ivanrest, Hitches by George on Division, or any of the RV shops on S. Division, all you need is a adapter, it is NOT Rover specific.
You need to go from a 7-round to a flat-4 plug, start calling, they will have it local.
Old May 17, 2010 | 03:01 PM
NiteTrain's Avatar
nobody you've showed it to has seen a standard american 7-pin connector? where do you live?
btw, i think they're called 12 N type plugs
Old May 18, 2010 | 09:22 AM
jbriggs's Avatar
Mine had HELLA stamped on it. Try them. I got rid of mine and put a flat-4 pin on instead.
Old May 18, 2010 | 11:38 AM
discomedic4's Avatar
You dont' even have to get rid of it. Just splice the flat 4 in to the wires coming in to the round 7 pin or buy the adapter. Then you can hook up to both set ups. That's what I did. My flat 4 is spliced. Just make sure you get the right wires spliced together. Also AutZone doesn't know what they are talking about. Last time I was in for trailer wiring (been a couple years though) they even had both the adapter and flat 4 harness. Good luck.
Old May 19, 2010 | 12:46 AM
jbriggs's Avatar
I had the adapter and it didn't work. Went with the flat 4 and it works great and I can haul trailers that aren't mine. And I agree Autozone hire average joes off the street that don't know crap or they are bad back-yard mechanics. Just my expierience. My advice, read, read, read. You can learn a lot by reading these forums and the manual for your vehicle.
pauldavidanthony
Mar 16, 2013 12:31 PM
grandkodiak
Apr 8, 2011 08:27 PM
ptelhomme
Oct 21, 2008 09:42 AM
jyoung
May 25, 2008 02:11 PM
snorlax
Apr 7, 2008 02:16 PM
